| The learning curve now goes circlular... !!!!! ![]() So can you sum up the cause and effect easily for me? I now understand that: the circle center is either referenced from the original zero/zero position, or the circle centre is referenced from the start of the arc point. In both cases the circle centre coordinates are specified, so how can one produce radical differences from the other? And how should Mach3 be setup by default? |
Circles and arcs, or, more specifically, G2 and G3 moves.
Typically, the flashing warning doesn't indicate anything "Abnormal", but just different from the default.
The best thing to do is to specify the mode in your g-code. G90.1 = Absolute IJ, and G91.1 = Incremental IJ. Placing the code at the start of your program will put Mach3 into the correct mode when you run the code, and it won't matter what the default mode is set to. And I believe that the code is modal, meaning that if it's changed by the g-code, whatever it's changed to will remain in effect until either you change it, or another g-code command changes it. Here's how I do it. G20 G40 G90 G91.1 M3 G0 Z0.250 G0 X2.000 Y3.000 Z0.250 G1 X2.000 Y3.000 Z-0.010 F50 G2 X2.000 Y3.000 Z-0.010 I0.000 J-1.000 F100 G0 X2.000 Y3.000 Z0.250 G0 Z1 M5 M30
| Gerry, many thanks for such a clear answer. and just to let you know... I cut my first shape last night, what an achievement! Build and configure the machine Learn to draw in Autocad Learn how to toolpath and generate gcode in CAM Learn how to setup the job on the machine. CUT.!!!! ![]() What a feeling, such a steep learning curve, but to watch it cut your first ever bespoke peice was truly a great buzz!!! I hope you can remember that feeling? Cheers |
| Bridgeport Interact 2 -- tachometer mode vs. voltage mode? | ichudov | Bridgeport and Hardinge Mills | 2 | 06-28-2010 01:24 PM |
| Absolute cords reset in handle mode | quasarix | Fanuc | 14 | 03-08-2010 12:42 PM |
| New Machine Build- spline mode nurbs mode | cooltool | CamSoft Products | 4 | 03-10-2009 02:03 AM |
| Problem- Incremental Vs Absolute mode | chilly2k | Mach Wizards, Macros, & Addons | 4 | 03-06-2009 04:54 PM |
| What is - Torque Mode? Position Mode? Speed/Velocity Mode? | sunmix | Servo Motors and Drives | 25 | 10-26-2008 03:53 AM |
