Frank
I don't use Mach with my mill; but setup should be the same
I simply used a stepper 300oz/in and reduced the drive by 3-1; so I get 900 oz/in hold
Next; calculate the step value and input to the setup screen
Then test the set-up; here's how I did it ; setup a DTI on the axis with something as a stop and set the DTI to 0
tell the controler to move 360 that will be 1 rev; after you pull the DTI point out of the way (use a 1" travel)
Once the stop clears the point; simply return it to the fully in position
Once the rotation stops; see if your back on 0; if not adjust the step value by small amounts; I got mine dead nuts
LinkBack URL
About LinkBacks
