I am running mach 3 and dolphin v10 on my new Seig KX1 and I am programming in MM and the mill is in MM. z axis seems fine, but x and y jog fine. but when I run the program or run the regen on the control everything seems tiny. I run the part and it looks like its not moving. Any ideas? |
| What are you're default units set to?
I believe it is all in metric, I've checked the settings in Mach 3 controller and in the Dolphin CAM. Every time I start CAM a window pops up with options including inch or metric. I always choose Metric, All my read outs are in metric in the controller. In CAM under set up>machine type> mill> it is set to metric. In the Controller Mach 3, under General Logic Config The G20-G21 box is blank (unchecked) for _ LOCK DRO's to Setup Units. Should this be checked? One funny thing is the diameter of the cutter changes once the program is loaded. I set the tool info in mach 3 to 6.37mm, and I also set the same info when writing the CAM program and it changes to 161.798mm??? I am using a template program to cut a simple rectangle pocket. The only other thing I can think of that might be funny is that I have written the program in CAM, Post Processed it from Dolphin CAM so it is now a .ppr file, then I load it from the "My Documents" folder. I've included pics of Regen and Tool Setting changes before and after the program is loaded. Am I right that it is cutting, but just really small? I can't thank you enough, thanks again so much. Kind regards, Mark Stehr |
| The G20 in the upper right of the first pic tells me the machine is set up in inches. When you load the g-code with a G21. it's multiplying the diameter by 25.4, thinking it's displaying in mm's. Or the other way around. You're definitely mixing units.
| I'm guessing the machine is set up in inches, and the g-code is in inches, but with a G21 in it.
| Newbie- How do I make CAD/CAM size match machined size? | RedCoder | Benchtop Machines | 5 | 12-07-2010 04:13 PM |
| Via shape/size and wire size. | Drools | PCB milling | 0 | 08-14-2009 09:47 AM |
| Drawing Size and Cut Size Differ - Plasma | ADucci | LinuxCNC (formerly EMC2) | 5 | 10-05-2007 04:52 AM |
| Drawing Size and Cut Size Differ - Plasma | ADucci | Mach Plasma / Laser | 0 | 10-04-2007 08:49 AM |
| X3 base size or minium bench size | kenrc | Benchtop Machines | 2 | 02-04-2007 06:50 AM |
