Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-09-2011, 09:28 PM
MAS MAS is offline
MAS is on a distinguished road
over traveling
Hello, I have a job that requires several small slots to mill in a tube every 3-3/4". From the first slot to the last is 30", my little mill x-axis travel is about 22". My question is: is there a way where I can run a program to do this job and the program would stop near the end of my table travel so I can reposition the tube then touch 'cycle start’ and have the machine finish the rest of the slots.
The program would have to flag me to index the tube, travel back the opposite direction and start milling the slots till it milled the last one.
Is this possible to do with Mach 3? I know it can be done with the Omax waterjet software as I once had an aluminum sign cut that was 12' long on a 2'
x 4' machine.
Thanks in advance for your help.
Old 06-10-2011, 04:23 AM
wildwestpat is on a distinguished road
Try thinking f this as simply a run of 5 repeats combined with a second run to complete the job having reset. A jug which could just be 'vee' blocks would simplify the resetting as one at the centre could remain in place an save angular alignment if the tolerances work out for you. As you have to reset the work on the table I do not see the need for an automated stop feed - reset work (similar to tool change) - continue. There are safety issues with a major resetting with the computer still in control.
Work safe - regards - Pat
Regards - Pat
servos not traveling proper distance, new install of 2.0 replicapro Mach Mill 0 05-07-2007 11:45 PM
Father is traveling to US Arizona... Konstantin CNCzone Club House 0 01-19-2007 04:29 PM
Traveling to China, looking for a micro/mini lathe Konstantin Mini Lathe 5 11-18-2005 10:19 PM
