Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 05-28-2011, 02:32 PM
jimmyaz is on a distinguished road
What the ....!
Hey guys,
I have CNC router that I run on Mach 3 (R2.0) work great... Recently I built a new machine using Xylotex (version 3 driver), plug it in and retune Mach 3, work great.
However, I went and bought a second desktop (Dell ThinkCenter) Window XP. Install the same Mach3 onto this one.... however I can not get it to work. Also, this comp have higher specs then the old comp...
When I am in the Motor Tunning, I can jog it back and forth just fine ( I did have to change Step Pulse to 1 for it to work). But when I exist motor tunning... then it will not work... when I try to jog, it stall. The jog is set at 100%....
I don't understand thisssss...wat is going on>?
Old 05-28-2011, 04:27 PM
So i took the new comp (the one that's not running the Xylotex drive smooth).. I hook it up to the older CNC/driver and it run that just fine.
What the?
