Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-28-2011, 01:42 PM
rivalote is on a distinguished road
Problem with smooth motion
Hi all,
I am running mach3 on a P4 3GHz, 2GB RAM PC (win xp sp3) with a homemade CNC, homemade electronics . When I am in motor tunning and setup an axis velocity (for ie. 2500mm/min) move the axis with up and down key it is move smoothly, but when I am in normal operation and jog that axis the movement is no smooth anymore like its loses steps.
I dont know if I have to use optimization file for win xp.
Any ideas?
Thanks.
Old 04-28-2011, 01:55 PM
awerby is on a distinguished road
That's normal
Set the actual speed about 15% slower than what seems best in Motor Tuning. You might need to do optimization too, but try this first.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
Old 04-29-2011, 07:41 AM
Hi Andrew,
Thanks for response. So you are saying that if I set up 2500mm/min for max vel in motor tunning, my real max vel will be 85% of that, aprox 2125mm/min.
I will try that, thanks.
Old 04-29-2011, 10:47 AM
ger21's Avatar
Imo, it's not normal, but I've seen it reported from other users. Unfortunately, I don't have an answer for you.
Old 04-29-2011, 01:10 PM
mcphill is on a distinguished road
It is most assuredly NOT the computer, unless it is too new. You don't need a new/fast computer to get MACH3 running well. The P4 series is a good point in hardware evolution, though. You should absolutely do the MACH optimization steps!
If it means a clean install, DO IT!
http://www.machsupport.com/downloads...timization.txt
Old 05-09-2011, 05:06 AM
Grebbo's Avatar
Grebbo is on a distinguished road
Do you have Constant Velocity set in your G code or in Mach??
MyCenter 1 motion problem agood01 Kitamura 0 01-26-2011 09:54 AM
Problem- CNC Mill motion problem chns General Metal Working Machines 3 05-21-2010 11:41 PM
Just IN- Smooth Linear Motion in Compact Spaces with Low-Profile Redi-Rail® Pacific Bearing Product Announcements & Manufacturer News 0 09-22-2009 04:44 PM
Smooth motion required high feed 3 axis surface milling cncjoy Fanuc 11 10-13-2007 01:03 AM
smooth motion... howling60 CamSoft Products 11 06-08-2006 06:08 AM
