Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-20-2011, 03:27 AM
rimawi2008 is on a distinguished road
help me in stepper calibration
hello , every one
i have a problem with mach3 i make my calculation for step per and it is 119.2 i add this to mach3 motor tuning and select mm as my unit
the "step per"mean when i send 119.2 pulse the machine move 1mm .
but mach3 move 5mm when i use microcontroller and send 119 pulse the machine move 1 mm
i tray to make calibration in setting alt6 but it doesnt work ?
what can i do ??
Old 04-21-2011, 12:30 AM
neilw20's Avatar
neilw20 is on a distinguished road
Look at the Mach3 manual 5.5.2.3 ... Automatic setting of steps per unit
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 04-21-2011, 10:49 AM
thank you neilw20 for replay
put i tried it and didnt work good it is stell error
Old 04-21-2011, 12:12 PM
zeed is on a distinguished road
Recently had some serious calibration problems,could not calibrate my X axis to move with precision.When calibrated on short distances it made a mess on longer distances and vice versa...
After a lot of mecanical repairs problem was the same.
And solution:Changed my pp port setting from ECP to EPP and problem solved.
Do you have microstepping on your drivers?
What is your leadscrew pitch?
ps:
I always use mach3 calibration and it works exelent.
http://zeed-diyproject.blogspot.com/
Old 04-21-2011, 03:35 PM
thank you zeed for replay
i used microstepping motor driver that i design , i design it to make one revolution when take 6400 pulse
and my driving system is belt
there is the way how i calculate my parameter
1- make one revolution of motor by sending 6400 pulse from microcontroller and measure haw axis move and it is 53.69 mm
2- then i calculate the step per unit by this equation 6400/53.69 = 119.2 pulse
3- i put this value in config > motor tuning > step per
4- i tray for get my best velocity and acceleration by moving cursor and apply the new parameter
when i tried to move the x and y axis 5mm by g1 x5 y5 z0 they move incorrect value i tried calibration in setting alt6 but it doesnt work best value is error about .4mm and it is large error.
when i send 119 pulse from microcontroller to my machine it is move exactly one
mm.
how can i convert my lpt from ecp to eep?
thank you
Old 04-21-2011, 07:01 PM
neilw20's Avatar
ECP settings is in BIOS.
Reboot computer, while hitting <del> key (is most common)
Or read the mother board manual.
Old 04-22-2011, 12:34 PM
thank you
Need Help!- Kitamura Calibration help mechman5000 CNC Machining Centers 1 10-30-2009 05:29 AM
Help to improve Calibration ?s. Stampede Calibration & Measurement 3 01-05-2009 11:13 PM
Newbie- Calibration metalfixer CNC Plasma and Waterjet Machines 5 12-22-2008 04:27 AM
CMM Calibration in NorCal kccrusher Calibration & Measurement 8 08-27-2008 12:52 PM
Calibration as a buisness? kevinb Calibration & Measurement 4 07-18-2008 01:37 PM
