Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-12-2011, 08:26 PM
justin bowser is on a distinguished road
Need help with config
I am reposting most of this from the "Engraving Machine" section as I feel this is probably a Mach 3 configuration issue.
I purchased a little Chinese 3 axis router/engraver and have everything set up nicely except for spindle control. When I first boot up the PC the spindle is off but as soon as I load Mach3 the spindle starts and will not shut off until I reboot the PC.
I have ordered a little 25 pin breakout board so I can hook up the scope and look for signals as maybe I am trying to control the wrong pin
Anybody have any ideas?
Thanks,
Justin B.
Old 05-09-2011, 05:00 AM
Grebbo's Avatar
Grebbo is on a distinguished road
hi,
what sort of spindle are you running?? and how is it connected to your computer?
Old 05-09-2011, 07:53 AM
Just turning it on and off, I got it figured out. It appears you configure a "motor output" pin instead of the one called out as "spindle".
Thanks...
rs-232 pinout config Michael82 Fanuc 5 02-04-2012 07:08 PM
Need Help Config M3-M5 Camands woody8750 Mach Software (ArtSoft software) 11 08-30-2009 08:33 AM
Problem- X2 machine config help cnc-king Mastercam 7 03-03-2008 08:25 AM
Need Help!- Config Mach3 rex2 Machines running Mach Software 0 01-26-2008 03:52 PM
How do you backup your config. CATCH22 Mach Mill 5 12-20-2007 09:13 PM
