I'm alway behind the times. I just heard about cutting internal threads with a milling machine. I've got a CNC Wells Index with Mach3 as the controller. Can someone point me in the right direction on how to research the operation? It may not be possible with the machine and controller I have. I'm not sure I'm even using the right name. What kind of program is used to generate the code? Any and all help is appreciated. Thanks, Aj |
| Do you mean thread milling? You need a 3 axis mill. I used Visual Cam to generate some code, but it didn't do what I needed, so I wrote my own by hand. You are just making circles (G2/G3) with the cutter and moving down continuously in a helix by specifying a change in z for each circle. I started a thread about it in the diy router section.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html |
| As stated you need a 3-axis machine (XYZ) Mach has a built in Wizard to do thread milling. Look at "Wizards" button on the control screen. It will bring up a list of wizards. Thread milling is at the bottom of the list. You'll also need a thread form milling cutter. Works a charm. Sage |
| Threading mod to ElDorado mill | pfarber | Shopmaster/Shoptask | 4 | 05-07-2010 08:26 PM |
| CNC Threading on a mill ?? | zaebis | General Metal Working Machines | 3 | 07-28-2009 07:02 AM |
| Help with threading on a CNC mill | shorety | General Metalwork Discussion | 9 | 06-13-2009 09:15 PM |
| Using the Mill as a Lathe; Single Point Threading | Geof | Haas Mills | 10 | 02-07-2008 01:28 PM |
| Internal threading on a cnc mill | jime | General Metalwork Discussion | 5 | 11-14-2007 09:42 AM |
