| I have set my Gecko & stepper & Breakout board up and wired them carefully, but no matter what motor I use, I can NOT get the steppers to spin in both directions! The motor jogs smoothly, and I'm convinced its a Mach2 software setting! Step is using pin 2 and active HI Direction is using pin 3 and active LOW Please help me! |
| Are you using Mach2 or Mach3? In the other thread, I said to increase the direction pulse width. In Mach2 it's called direction prechange. both are in the motor tuning.
Changing the direction prechange shouldn't do that at all. What did you set it at?
| ViperTX: both Mach2 & the Bidirectional Breakout board are using the same pins. ------------- PoppaBear10: I have set both outputs to Active LOW ------------- Ger21: Your right, I was confused with the Acceleration & Velocity. When I set the Direction Precharge to 3, the motor ran smooth in one direction, and vibrated without spinning in the other. |
| Just make sure it's set for pins 2-9 to be output. Try increasing the direction prechange to 5,10,15,20,25 and see if it makes a difference.
