Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 03-21-2011, 03:08 PM
gothdragon is on a distinguished road
Angry problem in mach 3 mill z axle over heat's
my problem is my z axle is over heating and it's only my z axle
I well explain the best I can so please bar with me
this is a home made cnc.
probotix 3 axle kit
24 Volt 6.5 Amp Switching Power Supply
motor is
166 Oz In. Hybrid
1.8° /200 Steps Per Rev.
2 Amps Current Per Phase (Uni-polar)
6-wire Uni-polar or Bi-polar
NEMA 23 Frame
now here is my problem
this or uni- polar motor's . but the z axle over heated the uni polar board so I had to use one of my bi polar board's 4 wire setup motor or 6 wire
the motor can be used as uni or bi
{ this board I have the bi polar and uni polar chip's or not connected to board
they or ran with a cable so I am runing both uni and bi }
was working ok but the motor over heated after 3 min run and I mean
3ed degree burn over heat
I thot I fixed it in the motor tunning but I guess I was wrong
now I burnt out the bi polar chip and need to order a new one
this only with z axle set up in mach 3 and I feel it is something I am doing inside mach 3
I do know that uni polar and bi polar have deferent setup but I don't no nothing about bi polar setup's so im asking for help
also I can not seem to get the z axle to line up with the y and x axle
if I make something the timing is off
the z axle seem's to acked like it's getting back lach before it hit's anything
and no sign's of backlash
also noted I am using home depo screw's they or y 3/8 8 ft x 3/8 4 ft and z 3/8 1 ft sorry no acme screw I do not recommend this to no one
p.s I am using spill check sorry for english grrrr german here
time do's not matter stoping it do's if you can stop time for one hour thin that hour would be forever
Old 03-21-2011, 04:02 PM
if you need info on where i got this board and mmotor's at here is the link it has all the info on what i am runing so you can better help me with
3-Axis CNC Stepper Motor Driver Kits
and the bi polar chip is SideStep Stepper Motor Driver - Bipolar Stepper Motor Driver
the board is great for someone new like my self just lost on this z axle thing othere thin that everything els works great
Need Help!- Possible Mach 3 problem on Legacy Mill RADCO Mach Software (ArtSoft software) 6 06-02-2009 08:58 PM
Need Help!- 15xt X-axle problem Masi Fadal 3 04-07-2008 10:39 AM
Stupid problem - jogging incremental Mach 3 mill Green0 Mach Mill 2 06-23-2007 02:50 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Anyone uses beltdrive for y and x axle?? Bosen Open Source CNC Machine Designs 4 08-17-2006 11:17 PM
