Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 03-20-2011, 10:40 PM
rainnydayx is on a distinguished road
Mach3 - G code loading problem
Hi mentors,
I need some help with my current problem loading G-code into Mach3.
I drawn a part by Solidworks 2010, then used MasterCam X3 to generate G-code. I used pocket feature (from tool path) on the drawing part. It successfully verified the toolpath from MasterCam and generated G-code saved as .NC file.
I uploaded the .NC file into Mach3 to run the program on my Hobby CNC. The toolpath on Mach3 just showed an empty block. I don't know why. I previously could generate the simple program with a rectangular and drill couple holes. But it didn't work with the more complicated program.
Your help is greatly appreciated.
rainnyday
Loading g-code from BobCAD flyzoome Mach Mill 4 04-02-2012 07:58 PM
Mazak Matrix 3-digit G-code File Loading fbergski Mazak, Mitsubishi, Mazatrol 9 01-11-2011 08:12 AM
Need Help!- upgraded thread, now Mach3 changes distance after loading files nicanor76 DIY-CNC Router Table Machines 4 12-17-2009 09:22 AM
New Model Relief Loading Problem Jessica ArtCam Pro 2 05-30-2007 07:11 PM
Problem Loading Master on HURCO KM-1 JREEN2 General CNC (Mill and Lathe) Control Software (NC) 0 12-05-2004 05:12 PM
