Results 1 to 5 of 5
Thread: Adding cycle start to mach 3 mill
    Registered Dr Doofensmirtz's Avatar
    Apr 2010
    When adding a cycle start button to mach 3. What goes on the other end of the switch?
    If it goes to pin 15???? input, do you use a 5+ volt DC source, or ground the pin to make it activate?
    Thankx,
    Heinz D.
    UUU
    UUU is offline
    Apr 2010
    UK
    You ground the pin. Note that this will be to the PC ground potential (on other parallel pins) which may differ from your machine ground.
    Dec 2003
    Quote Originally Posted by UUU View Post
    Although on modern MB's the MB ground plane AND the PC power supply common is at ground potential, likewise, so is the parallel port 5v common.
    At least this is what I have always discovered?
    The usage of 'Ground' instead of 'Common' can be misleading.
    Although your PP common may be at ground potential, Never use machine ground as a conductor.
    Apr 2010
    So then, where would be the best place to get my ground from for this type of switch? If I find a pin that is common inside the parallel port, or the breakout board calls it common/ground use this?
    Thankx,
    Heinz D.
    Dec 2003
    Pin 18 to 25 are normally 5v commons, you may have to confirm it with a meter check.
    1. Need Help!- MACH 3 cycle start button
      By Rick7702 in forum Mach Mill
      Last Post: 06-01-2011, 03:53 AM
    2. Newbie- start of cut in arbitrary rough cycle
      By brummie31 in forum Hypermill
      Last Post: 08-19-2008, 08:00 AM
    3. Remote cycle start
      By REVCAM_Bob in forum Fanuc
      Last Post: 03-18-2007, 08:08 PM
    4. Remote cycle start?
      Last Post: 01-20-2007, 11:59 AM
    5. Cycle Start button
      By kaleem1 in forum Mach Software (ArtSoft software)
      Last Post: 12-24-2005, 03:05 PM
