Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 02-03-2011, 08:26 PM
Ark1 is on a distinguished road
Setting Z Coordinates
I am new to CNC and New to Mach3
I am face milling a part .030" from the top of my vise. What I have been doing is using a brass .030" feeler gauge between the top of the vise and the face mill tooth. Zero axis lower the table .315" ( this is the Max depth cut last pass) then reset the axis to Zero. Is there a way just to enter .315" in the DRO and making it accept that value?
I know I am missing something, just cannot seem to find how to do it.
Thanks.
Ark1
TonyK.
Old 02-03-2011, 08:30 PM
ger21's Avatar
Hit enter after typing in the number.
Old 02-03-2011, 09:26 PM
Thanks.
Gerry thank you.
The learning curve is frustrating at times. I think you bailed me out with the same answer in the Mach3 Mill Addons.
One day I will get it.
Once again thank you.
Ark1
TonyK.
Need Help!- IMG to Coordinates YoJoey Laser Engraving & Cutting Machines 4 01-28-2011 02:57 AM
Setting the machine x,y,z coordinates surrealism Taig Mills & Lathes 1 06-17-2010 10:32 AM
setting work coordinates through program lsrengineering Haas Mills 2 06-08-2010 09:07 AM
Trying to set origin coordinates LockTech LazyCam 5 11-25-2009 11:23 PM
G92 coordinates monaro mike Fanuc 12 07-28-2008 07:27 AM
