| Look at the diagnostics page. When it homes, the LED should come on, then go off as it backs off. Are you saying the LED stays on? It's only supposed to back off the switch enough for the switch to open.
| So after you home, the LED doesn't go out? Is there an error message?
| Does the light go out? And is there an error message?
| Last time I ask this. When the machine hits the switch, the light comes on, But, does it stay on, or go out.
Thanks for the help on this Gerry Im very new to all this, The light stays on, with no error, the axis pulls at home but does not back off the switch, It also sometimes triggers a estop limit switch half way through a jog could this be switch noise ? |
#10
| If you get a limit error without hitting a limit, then yes, it's switch noise, which is most likely causing the homing problem. In general config, upper right, set a debounce of 2000 and see if it'll then back off the switch. It only backs off a very small amount, but the LED should be off.
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
| Is it possible to use the home switch as the limit switch as well? | Darc | Mach Software (ArtSoft software) | 2 | 10-23-2005 12:50 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
| O/T Friends coming home.. | Rekd | CNCzone Club House | 1 | 04-28-2004 12:22 PM |
