Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 01-11-2011, 07:27 PM
KASA Guitar is on a distinguished road
Mach 3 problem, probably my fault
I am using CamBam, Mach 3 and a Gecko 540. My mill is a FLA 100 and has been working as expected until a few days ago. I should also mention I built the Machine between Thanksgiving and Christmas and I am a newbie.
My Problem: I am cutting guitar parts and have done several successful cuts. I don't know what I changed but now when I cut a "pocket" it comes out rounded off in two opposit corners. See attached picture. This is a neck pocket roughly 2 inches by 3 inches. Everything worked fine until suddenly this started. Circles, profiles and other shapes work fine. This also happens in engraving. The letters come out with a rounded part. I have spent hours searching the forums for a similar problem but no luck. Does anyone out there know what I have done?
Old 01-11-2011, 07:39 PM
ger21's Avatar
You turned on Constant Velocity (CV). I'm assuming it displays correctly in the toolpath window?
Old 01-12-2011, 08:55 AM
I made sure CV is on and it was. The cross hairs in the tool path window do the same thing. they make the curve just like the finished product.
Old 01-12-2011, 08:59 AM
I will attach the nc file if that helps.
Old 01-12-2011, 09:03 AM
OK now I really am a newbie. I tried to attach the nc file but don't see it. This is my second try.
Old 01-12-2011, 09:32 AM
mactec54 is on a distinguished road
KASA Guitar
To post your program, save it as a text file, then it will post,many programs will do this for you, MS word works well
Mactec54
Old 01-12-2011, 09:45 AM
Thanks, here is a try saving it as a text file.
Old 01-12-2011, 10:31 AM
LeeWay's Avatar
LeeWay is on a distinguished road
You can try exact stop. It will be a little different, but it won't try to keep up speed, so it won't be cutting corners.
Lee
Old 01-12-2011, 10:35 AM
Thanks I'll give that a try. The odd thing is it worked fine until just about a week ago. Also odd is the "corner cutting" is only on opposit corners, not all four.
Old 01-12-2011, 10:37 AM
ger21's Avatar
Sorry, what I was saying is that Constant Velocity is causing it.
On the settings page, turn OFF CV distance and CV feedrate.
In general config, turn on CV angle and set it somwhere between 89-91°
  #11   Ban this user!
Old 01-12-2011, 10:38 AM
I forgot another strange thing. I sent the nc file to a friend who ran it with no problems. His setup is similar to mine.
  #12   Ban this user!
Old 01-12-2011, 10:48 AM
GER21, I think you solved it. I did what you said and set the angle to 90 and it solved one of the arcs. the upper left in the picture if previously sent. I change it to 89 and in simulation it works. I haven't cut wood yet. I'm setting up to try that now. THANK YOU.
Tags
mach 3, newbie needs help, pocket
VMC15 fadal, 88HS error#9, spindle driver fault, servo amplifier fault kin73 Spanish CNCzone 3 05-17-2011 11:26 PM
Problem- VAC Drive Fault and Clamp open/close Problem pesmith2 Okuma 4 04-01-2011 12:20 AM
Estopping Mach and other drives with fault condition jubee Gecko Drives 2 04-23-2009 03:03 PM
G540 fault problem jemmyell Gecko Drives 12 10-21-2008 05:50 PM
how do i get mach to halt for a servo fault fast89 Mach Wizards, Macros, & Addons 1 04-08-2008 02:10 AM
