Results 1 to 7 of 7
Thread: Mach3 and Cam Bam discrepancy
    Registered uspl's Avatar
    Sep 2010
    Hi all
    I am cutting (or trying to cut )two 5mm wide profiles, each is 2.5mm deep.
    The first is along the X axis, basically a trench 5mm wide, 2.5mm deep and 100mm long. At one end of the trench I have a 5mm wide arc profile, scribing a 90 degree bend that is also 2.5mm deep. The cutter is a standard two flute 5mm end mill.
    When I draw this in Cam Bam the two profiles overlap by 3mm to allow for under cutting at the very ends of each profile. What I want to finish up with is a trench 100mm long that then turns 90 degrees and continues for a further 50mm along the arc. All this looks great in both Cam Bam and in Mach 3 when I look at tool paths, cut widths etc. The end result is the trench and the arc are cut perfectly but they don't join; there is about a 2.5mm "under cut" where they should join.
    Any thoughts ?
    Registered cheetahcnc's Avatar
    Oct 2007
    Wouldn't you do a 5mm wide path with a narrower mill bit, so you can climb cut both sides? Just a suggestion, as the software, and machining process, might not like the large cutting contact at the radius/end.
    Jim
    Oct 2005
    us
    Sounds like cam bam is simplifying the cut. why not post the code as 2 seperate programs, run one and then the other. that way cam bam does not use any "logic" to determine what you want to cut. i think cam bam is thinking too much and has decided that you intended something that you have not...
    Just a guess...
    Nate.
    Ann Arbor Meechigan
    Oct 2005
    us
    also, what is you tool size set to? sounds like this might be a cutter-comp issue.
    Nate.
    Ann Arbor Meechigan
    Sep 2010
    Quote Originally Posted by cheetahcnc View Post
    Jim
    Thanks Jim
    I would use a smaller cutter but my JGRO setup means that tool changes are painful and inaccurate; the rest of the job needs much bigger profiles and pockets and some 5mm holes need to be drilled as well so a 5mm cutter does all the parts.
    I suspect some sort of cutter comp or inside/outside radius issue is at the heart of the problem as I also have a similar problem on another job where two trenches meet at 90 degrees and I have to force the vertical one way past where it should end in order to meet the horizontal one.
    Sep 2010
    Quote Originally Posted by nate View Post
    Thanks Nate
    The tool size is 5mm in CB and it is cutting the right widths on all my profiles and pockets, it is just the junction/overlap issue I cannot seem to fix.
    I'll try your suggestion on two programs and see how that goes.
    Cheers
    Sep 2010
    Fixed it
    0.9.8H Square pockets are squashed ovals - HELP ??
    It wasn't Cam Bam, it was Mach 3 and it was something I never would have thought of.
    Just like poor old HAL9000, I gave Mach 3 two conflicting instructions; keep a CV of 600mm but don't exceed the acceleration threshold. It did what it could and the result satisfied nobody.
    Hope this helps some one else.
    Regards
    David
    1. Differences Between Mach3 Mill and Mach3 Plasma?
      By cjjonesarmory in forum Mach Plasma / Laser
      Last Post: 11-18-2010, 10:12 AM
    2. Newbie- Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
      By router101 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-03-2010, 05:46 PM
    3. Need Help!- I cant get Mach3 to run
      By Crawler374 in forum Mach Software (ArtSoft software)
      Last Post: 09-07-2009, 01:11 PM
    4. help with mach3
      By chrispare in forum Mach Software (ArtSoft software)
      Last Post: 08-02-2009, 08:49 PM
    5. G-Rex & mach3
      By eloid in forum Machines running Mach Software
      Last Post: 03-15-2007, 12:50 AM
