Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 12-06-2010, 06:41 PM
rrrevels is on a distinguished road
Motor tuning window does'nt come up
I have installed a new version of Mach3 in a separate subdirectory in XP and renamed the original directory. Now when I start Mach and use the pull down menu for motor tuning nothing happens. The dialog box doesn't appear. All the other menu items work.
Anyone have any idea of what I must have done to cause this?
Thanks,
Russ
Old 12-06-2010, 08:30 PM
ger21's Avatar
In the new installation, or the old one?
Either way, try re-installing.
Old 12-06-2010, 08:34 PM
Hi Gerry,
Actually at the moment neither works. I will try a reinstall tomorrow when I can get back in the shop.
Thanks,
Russ
Old 12-09-2010, 05:10 PM
Thanks Gerry,
The reinstall cleared up the problem and everything is back to normal.
Thanks,
Russ
MOTOR TUNING corneliusbrown Mach Software (ArtSoft software) 3 06-10-2009 10:26 PM
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
Motor tuning br1 Mach Mill 1 02-28-2009 07:38 PM
Motor Tuning cookja01 Machines running Mach Software 1 03-07-2007 02:27 PM
Motor Tuning PEU Mach Software (ArtSoft software) 3 09-26-2005 11:48 PM
