Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 10-26-2010, 11:28 PM
fbmstar is on a distinguished road
Z axis stalling on rapids
Hiya all,
Havin' a little trouble w/ my syil CNC mill.
During a recent program run, my z axis stalled out on a rapid upwards move. This has happened a few times before with different programs and i mistook it for a mechanical binding issue. I set the accel to 3 (was @ 6), and ran it again, it still stalls. If i do a rapid jog, it works fine. If enter a run command of g00 z+1, it works fine. I can hear it pulsing at a much higher frequency during this program. I'm also using a G100, which can easily pulse this thing to a stall.
I'm perplexed as to why the program would make this stall, but other fast functions don't. I've tried it on different spots on the z axis, with the same results.
thanks in advance,
Brian
Old 10-27-2010, 07:56 AM
sdeering is on a distinguished road
I sounds like your program is trying to move the Z faster than it is able too. I would adjust the program.
Stephen
Old 10-27-2010, 08:47 AM
M250cnc's Avatar
M250cnc is on a distinguished road
Brian,
This can be caused by a too optimistic acceleration and velocity setting in motor tuning. Halve the values for the Z axis if the problems go away raise them till they come back then back off an amount for safety.
The other cause is a cnc setup with the power supply at a low voltage.
Don't forget to save the settings before you close the motor tuning dialogue box.
There were some dodgy Mach versions that allowed the max motor speed to be to be over ridden along with the feed rate. But the newer versions do not suffer
Help for those with z/x/y axis stalling xaruum Taig Mills & Lathes 2 06-23-2010 11:18 AM
oh no only my y axis keeps stalling stk2008 General Electronics Discussion 44 09-25-2009 05:09 PM
Y axis stalling/hanging up tdnp DIY-CNC Router Table Machines 7 12-15-2007 02:13 PM
Alarm,24&34 on Y-axis -only on rapids Robmatsuura General CNC (Mill and Lathe) Control Software (NC) 1 11-19-2007 09:14 PM
New 3 axis CNC machine w/1200 ipm rapids released RomaxxCNC Product Announcements & Manufacturer News 6 10-09-2006 07:35 AM
