Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 10-23-2010, 08:43 PM
LockTech is on a distinguished road
Accidently disabled movement arrows
Hi all, earlier I was setting up the mill and the next thing I know is the keyboard directional arrows stopped working. I am assuming I accidently pressed the wrong button to disable it. The keyboard seems to be functioning correctly, and on the mach3 screen, I can no longer "cycle jog step" or "change jog mode" buttons.
I tried restarting the software and computer, did not help, apparently it remembered the new setting.
I can mouse over the arrow buttons on the screen and travel that way, but I really need to get my keyboard buttons going again, anyone know of the setting I am talking about?
Keith
Old 10-23-2010, 09:24 PM
ger21's Avatar
Config>Hotkeys
Old 10-23-2010, 09:54 PM
I dont think thats it, since "cycle jog step" or "jog mode" buttons are disabled as well. I can load a different profile and it shows all the same hotkeys setup but the "cycle jog step" and "change jog mode" buttons work in the other profile.
Old 10-23-2010, 10:11 PM
ger21's Avatar
I don't know of any way to disable the keyboard keys. Sounds like maybe your .xml file is corrupt??
Old 10-23-2010, 10:16 PM
That could be. Just seems weird did it while in between runs.
On the tab window where you can normally set your "jog mode" to step. Those buttons arent lit up anymore, just like they were turned off. Also the amount to step, 1 .1 .01 .001 .0001 etc is not changeable either anymore. Pretty weird.
Old 10-23-2010, 10:18 PM
ger21's Avatar
You have jogging turned off, control-alt-J.
Old 10-23-2010, 10:22 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Keith,
Do you have Shuttle Mode enabled by accident?
Jeff...
Name:	Shuttle Mode.jpg‎
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 10-23-2010, 10:26 PM
Gerry, cont/alt isnt doing anything.
Jeff, no its not on, but it does light up and blink when I turn it on, but not fixing the problem
Old 10-23-2010, 10:30 PM
ger21's Avatar
Click the button, bottom of the Tool section, on the Program Run screen.
I thought the cont/alt thing would fix it because that sounds like something I would do accidently. But no luck
Old 10-23-2010, 10:31 PM
ger21's Avatar
And it's Control-Alt-J
  #12   Ban this user!
Old 10-23-2010, 10:40 PM
YES !! SUCCESS Thanks Gerry, didnt realize that was a J the first time, wasnt paying close enough attention.
Thanks again
Keith
My Arrows are sick. advt001 Cincinnati CNC 3 06-14-2010 06:07 PM
Keyboard Arrows Problem kolias DIY-CNC Router Table Machines 10 08-15-2009 04:31 PM
Need Help!- Look Ahead Control Disabled laser jim G-Code Programing 4 06-12-2009 12:35 PM
My table moves the wrong way when using jog arrows?!!! HankMcSpank Mach Software (ArtSoft software) 3 05-06-2009 10:21 AM
Can't use keypad arrows bcnc Mach Mill 1 10-24-2007 07:28 PM
