Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 10-02-2010, 12:15 AM
uspl's Avatar
uspl is on a distinguished road
Circles are ovals
Hi all
Runnign a JGRO build with Mach 3 R3.042.040 in demo mode.
The machine is cutting fine and reasonably accurately so far; I am only doing test custs in MDF while I tune the new build.
As the title says, circles are being cut as ovals, stretched by about 10% along the X-Axis.
So far I have:
  • Fixed a minor backlash issue on X
  • Checked the alignment of X-Y are as true to 90 degrees as I can measure
  • Tried the two IJ options for Inc or Abs in Mach 3
  • Tried cutting a pure rectangle to check alignment; all corners cut square and the rectangle was true
The setup also cuts text fine, nice and straight and algined.
I'm stumped, any suggestions appreciated.
David
Old 10-05-2010, 12:45 AM
uspl's Avatar
Fixed it
It wasn't 10%, it was actually 20%.
As I said, rectangles and squares were perfect, only circles were a problem. I was doing some CAM tests and happen to order two rectangles, 100mm x 50mm. One was aligned to the X axis the other to the Y axis. Lo and behold, they came out different sizes !!
I checked my thread pitch on both axis and found that my supplier had sold me two different pitches on the two different days I shopped for parts !! X axis is 1.5, the Y axis is only 1.25. I changed my Config>Motor tuning and presto my circles are circles. I didn't pick it up when making the nuts as I used HDPE and the rod just cut it's own thread.
Just goes to show, never assume.
Cheers
David
Old 10-05-2010, 07:05 AM
rowbare is on a distinguished road
Mach has a calibration feature that allows you to dial in your steps per unit quite precisely. Hoss discusses it and has a video showing how it works in this post: http://www.cnczone.com/forums/showth...ach#post563707
bob
Old 10-05-2010, 07:42 AM
neilw20's Avatar
neilw20 is on a distinguished road
David,
You are right!!
You can't assume.
It makes an ASS out of U and ME!
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 10-05-2010, 07:55 AM
john23 is on a distinguished road
i do agree on that ! Its such a big pain in the neck when my circles turns oval!! There would be a part where in which it is finished to size and a part which is undersize... In times like this i try changing cutters
Tags
mach3, new build, ovals
Ovals instead of circles??? X4 zaebis Syil Products 4 03-17-2010 09:09 PM
TNC145 ovals? Mike Woo Bridgeport and Hardinge Mills 4 11-05-2009 09:40 PM
Help!! Using Formulae to turn ovals with Mach3 rajiv.tctech General CNC (Mill and Lathe) Control Software (NC) 2 03-11-2008 10:23 PM
Ovals! cxixer Autodesk Software (Autocad, Inventor etc) 2 01-31-2008 06:32 PM
Kcam not seeing ovals properly monkamarm2000 General CNC (Mill and Lathe) Control Software (NC) 9 06-30-2005 02:40 PM
