Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 09-19-2010, 07:57 AM
electric2u is on a distinguished road
step and dir pulse ?
can someone tell me when i might need to use the step pulse and dir pulse in motor tuning? my cnc seams to run about .015 off even after doing the axis calibration. (can't find nothing loose)
thank you
kevin
Old 09-19-2010, 08:13 AM
ger21's Avatar
Depends on the drives your using. Most work well with the pulse width set to 2, but some need it set much higher.
IF you need to set it higher than the drive manufacturer recommends, it could be do to a weak parallel port.
Old 09-19-2010, 08:50 AM
so nothing to do with .015 off?
Old 09-19-2010, 01:53 PM
Torsten's Avatar
Torsten is on a distinguished road
You can change the steps per inch settings to come out closer.
The important question would be are you sure you are not just skipping some steps because you are asking more of your motor then it can deliver.
Make sure to run some tests at conservative acceleration settings with a slower then maximum feedrate to ensure your deviation is consistent.
Good Luck
Old 09-19-2010, 02:32 PM
that is a good question, i might be doing that. thanks
Step Pulse Multiplier RotorRouter Gecko Drives 15 08-02-2010 01:00 PM
step = pulse??? lucky021 Canadian Club House 2 10-29-2009 03:10 PM
Mach Step And Dir Pulse Width Brenck Mach Mill 3 10-17-2009 12:56 PM
step and dir pulse dgalaxy Gecko Drives 1 04-21-2009 07:38 PM
Step Pulse Sniffer Mariss Freimanis Gecko Drives 40 12-01-2008 06:20 PM
