hi iam newbie please i have funny problem after load gcode i press start my z axis should engraving into wood i gose oppisiet it go up ? how it will engraiving down not up please? thanks. Last edited by alkoche; 09-06-2010 at 11:50 AM. |
| z0 is normally the top of the part in most cases if you want to cut into the part the value has to be neg. z1.0 is one inch above. assuming inch's on mill and not metric. If you DRO is goes from 0 to 1 and your cutter is going down, then your direction in mach is backward for that axis. |
"G0 Z-1.0000" is the correct code to go down 1mm or inch on a mill in Mach3. The other option is to reverse the axis direction in the setup. |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 06:31 AM |
| New Machine Build- post for 2 axis ez trak versus 3 axis ez vision | tooolman | G-Code Programing | 0 | 11-28-2008 03:33 PM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 01:54 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
