Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 09-06-2010, 06:16 AM
xaco is on a distinguished road
how to make 4th axis move continuosly?
hello,my 4th axis is moving in steps of 1/4 of a degree,what can i make to make it move continuously? i have some motor on 4th axis thats written on it 2 steps/degree.its not microsteper motor and its dirctly conected to my 4 jaw chuck ,it dosnt have transmission. in mach3 i put in motor tuning in "steps per" box-4...so i have 4 steps per degree but always in steps...is there any way i can make it move continously?
Old 09-06-2010, 07:43 AM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
This is from the mach3 yahoo group,
Config> ports and Pins> motor output> enable the spindle and enter the pin
numbers for the indexer step and direction pins.
Don't forget to click on apply.
Next, click on Config> ports and Pins> Spindle set up> put a check mark in"Use
Spindle Motor output" and another check mark in step and direction.
Last go to
> config> pulley set up
and provide the necessary info.
Then in your G code you will need the M3 command and the S value.
Such as S 200 for 200 RPM
Old 09-07-2010, 09:43 AM
Last go to
i was taking about 4th axis,my spindle is separate from any pins and ports..but thnx... by the way ..my motor on 4th axis is 2deegrees per step,not 2 steps per degree as i mentioned..
Old 09-07-2010, 12:53 PM
GaryCorlew's Avatar
Yes I know, but that is how it is done
How to you make a stepper motor move? HereinCS DIY-CNC Router Table Machines 0 08-24-2010 12:45 AM
Newbie- Does a DRO make X Y Table Move? theNaTural Industrial Hobbies (Support forum) 4 06-13-2008 12:06 AM
Has anyone disassembled a Tormach into subassy to make a difficult move in? MadMax Tormach PCNC 5 12-06-2007 07:50 AM
Cant make it move hugo carradini General Electronics Discussion 0 10-12-2007 05:50 PM
Software to follow a spline continuosly fsalla General CNC (Mill and Lathe) Control Software (NC) 2 09-22-2005 07:01 PM
