Results 1 to 3 of 3
Thread: edged part
    Apr 2010
    Exclamation edged part
    Hi;
    I have one of those Toshiba 4 axis stepper driver board from ebay which is controlled by
    mach3 program.i have a good power supply for that.
    my retrofit mill is from central machinary that I am using it as a CNC.
    here is the problem:
    the parts i cut has depth line like steps on it and every layer that is cut is a little off from previous one.
    seems like if i cut squire pocket top and left side has sign of steps but right & bottom side is clean cut.
    I am not sure if i lose some steps or there is other reasons involved.
    the part i am cutting is plastic and the feed rate is 6 IPM at 1400 RPM with 1/4 endmill.
    is there anybody the knows the resone(s) and solutions for this problem?
    Registered fatal-exception's Avatar
    Mar 2006
    Sounds like you spindle is out of tram with your table.
    Search Google for more information about tramming.
    Paul
    Apr 2010
    tnx
    i will do my research thanks for respond
  1. Problem- I need a very “small part” part catcher
    By Vern Smith in forum Haas Lathes
    Last Post: 08-24-2010, 08:55 PM
  2. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 01:18 AM
  3. sheetmetal part? flatten a rolled part?
    By Rich05 in forum Solidworks
    Last Post: 08-12-2009, 11:22 PM
  4. Verify Cut part to Design part.
    By CaseyCAM in forum NCPlot G-Code editor / backplotter
    Last Post: 11-01-2008, 10:22 PM
  5. Newbie- Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum General Metalwork Discussion
    Last Post: 03-15-2008, 07:35 AM
