Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-17-2010, 08:35 PM
electric2u is on a distinguished road
adding one more relay
i have a relay i would like to add, but don't know how to do it (program part). when the g code is done running i won't a relay to open (when it's running it closed) so that it well shunt the power to the cnc down (kind of like i walked away and fallen a sleep and i what it to turn off when it done) i know how to wire it, just don't know how to tell mack 3 to do this. sorry for the odd question but i'm an electrican and this stuff is fun to me.
thank you
kevin
Old 08-17-2010, 08:58 PM
ger21's Avatar
Create a macro and call it at the end of the g-code. if the relay is wired to Output one, the macro should be
ActivateSignal(Output1)
or
DeActivateSignal(Output1)
Name the macro something like M555.m1s and put it in the macro folder. When Mach3 gets to M555 in the g-code, it should turn off.
Old 08-18-2010, 05:18 AM
if i write a marco code do i have to put it in the gcode or will it just do it for me? i all some need to learn how to wrtie marco
kevin
Old 08-18-2010, 05:20 AM
Shelby Twp, michigan hear of that i'm in boyne city (up north)
Using a solid state relay as a main stop relay garagefela General Electronics Discussion 4 02-26-2010 04:27 PM
RPC with a relay Shanghyd Phase Converters and VFD 0 06-30-2009 06:02 AM
Need Help!- Adding an X axis power feed to my smithy 1220XL milling table.Adding an X axis power matridium Smithy 0 05-28-2008 10:37 AM
Another relay ? Bear General Electronics Discussion 4 11-23-2005 05:31 PM
Need Relay help... CarveJunky General Electronics Discussion 5 07-20-2005 08:52 AM
