Results 1 to 4 of 4
Thread: setting default screen
    Dec 2007
    UK
    I've just used machscreen to set up auto zeroing via limit switches on my machine.
    In order to use this screen, I have to go to View>Load Screens .
    How can I just set this screen to appear every time when i start up mach3?
    Mar 2003
    Shelby Twp, MI....USA
    If you made a screen that just does the autozeroing (sounds like it), then you have to laod it to use it.
    You should have added another page to your existing screen, with a button to display it.
    Dec 2007
    UK
    What I did was take the default screen and add code to three of the existing buttons on it, then saved it under a new name.
    The default was called 1024.set, and i called mine 1025.set
    Mar 2003
    Once you load 1025.set, it should load every time until you load a different one. Whatever screen is currently loaded should load again when you close and restart Mach3.
  1. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-13-2009, 07:35 PM
  2. Tool Life management setting screen
    By tmp120 in forum Fanuc
    Last Post: 01-29-2009, 03:38 PM
  3. Need Help!- OSP5000L (green screen) default parameters!
    By em322 in forum Okuma
    Last Post: 10-13-2008, 10:53 AM
  4. Replies: 6
    Last Post: 07-13-2008, 06:28 PM
  5. setting rhino to default to inches?
    By CNC Darren in forum Rhino 3D
    Last Post: 09-11-2005, 10:51 PM
