hello,i have A axis , and when i turn my machine in Mach ,all 4 engines of machine get current ,sometimes ,i want to be able to turn A axis manualy without turning off machine,so i want to turn off only A axis...can i do that in Mach or i should put a swich in A axis wire? Thanks |
thx jalessi,but as i remember i did that,but problem was that current still coming in my A axis making it not possible to rotate it by hand while the machine is on. i will try it again... |
| Xaco, Sorry for the confusion. Most stepper drivers have a enable-disable terminal, see attached image for an example. This will allow the motor to free wheel. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
yes,that would be it ,i was hoping i can do it in mach3 in a way.....anyway..thank you |
| Xaco, You could assign an available output pin to control the enable-disable function of the stepper drive. Jeff...
what if i just cut the wire from box to motor and put a switch,how many wires can i expect? and would it hurt my machine if i swich off and on with swich during mach3 is working? |
YES, it will probably damage your controller card, as every controller I have ever seen warns specifically NOT TO connect or disconnect a motor while the controller card is powered. |
is it ok to swich it of and on while mach3 is off? or if its not working gcode at a moment? or it would hurt if i swich of and on even if only mach3 is on...when exactly it wouldnt hurt to swich on and of? |
| TM-1 Y axis limit switch alarm | jwknow | Haas Mills | 2 | 10-26-2007 03:53 PM |
| How to switch axis directions? | juzwuz | LinuxCNC (formerly EMC2) | 8 | 12-31-2006 08:05 PM |
| Y axis limit switch | raytor | Benchtop Machines | 3 | 10-10-2006 08:48 AM |
| Z axis zero indicator switch | cnc rider | Mach Mill | 4 | 09-28-2006 11:00 PM |
| home switch for rotational axis | xyz100 | DIY-CNC Router Table Machines | 1 | 07-31-2006 01:14 PM |
