Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-05-2010, 05:46 PM
MugenSeiki5T is on a distinguished road
Gcode is mirrored
I'm having an issue with Mach where when you load the gcode file, it loads it mirrored, what I mean by that is that ok say I have a part that is 3 inches long on the left side of x,y 0 and 2inches long on the right side of x,y 0 I generate the gcode from vectric cut 2d, cambam it doesent seem to matter, and load it into Mach to cut, when loaded, the part is 2 in on the left of xy 0 and 3 inches on the right of xy0. If this doesent make sense let Me know and I'll do some screenshots but has been an issue for a while, I never bothered to ask cause it never really caused a problem till now, I'm hoping someone can shed some light on what may be going on,
thanks
Old 08-05-2010, 06:30 PM
ger21's Avatar
Is it mirrored, or just shifted over? You'll need to post some screenshots.
Old 08-05-2010, 07:01 PM
mcphill is on a distinguished road
Which axis? Assuming it is X, if you move + X using the jog button, does your spindle move left or right?
Old 08-05-2010, 09:03 PM
Gcode is mirrored
here is a pic of what it looks like when the file is loaded, which actually is correct, im sending this from my phone so I can only attach one pic at a time to a post. ill post what actually gets cut in another message
Old 08-05-2010, 09:06 PM
ger21's Avatar
If the screen is correct but it cuts backwards, then your machine is set up backwards. You need to reverse your X axis.
That's not what you said in your first post.
Old 08-05-2010, 09:07 PM
Gcode is mirrored
yeah, I know my z height was off grrr stupid wood lol half inch is supposed to be half inch right? well except after it goes through a planer and it takes off 5 hundredths or so grrrrr gotta keep that in mind next time, not used to cutting wood
Old 08-05-2010, 09:08 PM
Gcode is mirrored
If the screen is correct but it cuts backwards, then your machine is i set up backwards.
I
I know, sorry, I was frustrated an not thinking clearly when I said that gotta forgive stupidity lol
Old 08-05-2010, 09:09 PM
ger21's Avatar
If I'm cutting wood that's supposed to be 1/2", I first zero to the table, then jog up 1/2" and re-zero. Much less damage that way.
Gcode is mirrored
+ X moves the x axis to the left
Old 08-05-2010, 09:11 PM
Gcode is mirrored
never thought about that, that's an extremely good point. im still pretty green at this kinda work so any tip like that is very welcome
Old 08-05-2010, 09:15 PM
ger21's Avatar
Table or tool?
The tool should move right, the table to the left.
  #12   Ban this user!
Old 08-05-2010, 09:16 PM
Gcode is mirrored
Table or tool?
sorry, the table moves to the left, this is a taig micro mill
Mirrored: What's going on here? Sheridan Basses Musical Instrument Design & Construction 4 05-09-2010 01:00 PM
mirrored parts problem MadPickinSkills DIY-CNC Router Table Machines 12 08-01-2009 11:29 AM
Work is Mirrored??? keelhauled Post Processor Files 5 03-30-2009 01:38 AM
Axis is Mirrored s3r4ph LinuxCNC (formerly EMC2) 3 09-23-2008 05:21 PM
Output is mirrored?? BobLWeiss Carken Products (Deskam, DeskCNC etc) 3 01-03-2005 11:54 AM
