| Hello, i would like to swich X to Y axis and Y to X. Currently my 4th axis is aligned with Y axis what makes me problems to find postprocesor and make g-code, so i thought to swich axes. i dont want to move 4th axis to put my current moving X axis cos my 4th axis rotary table is very heavy so i put it fixed "outside" the machine aligned with Y axis,rather than fix it on moving x axis. So i thought to swich in Mach3 X and Y axis to get rotary toolpath X->A cos i dont know how to get Y->A toolpath in ArtCAM. thank you |
Plug the X cable into the Y socket, and the Y cable into the X socket. Any moves down what used to be the X direction will now go down the Y direction and the old Y direction will become the new X direction. You'll have to remember that when laying out a new flat part, but the 4th-axis code should work okay with it. You can do the same thing by going into Config/ports and pins in Mach, and switching the values, but that's more difficult to explain... Andrew Werby www.computersculpture.com |
if it was working correctly before. The advice you got was correct; switch the step and direction pin numbers from the X axis to the Y axis, and from the Y axis to the X axis. I believe the "low active" pin 2 should remain low active in the new Y axis, but check to make sure that everything works correctly, and the motors go in the right directions - if not, these are the things you'll have to change. Andrew Werby www.computersculpture.com |
| Need Help!- Mach3 A axis (4th axis) setup? | cadcamslawek | Mach Software (ArtSoft software) | 10 | 01-17-2012 08:23 PM |
| Need Help!- How to assign 5th & 6th Axis to Slave when Pin 2-9 already used in 4 Axis for Mach3 | guy2b1 | General Electronics Discussion | 8 | 10-29-2009 08:09 AM |
| Newbie- Mach3 Z-axis disable when not in use | Erant | General CNC (Mill and Lathe) Control Software (NC) | 3 | 05-18-2008 06:52 AM |
| Need Help!- 6 axis screen of mach3 | ayhan | Mach Software (ArtSoft software) | 0 | 02-21-2008 04:24 AM |
| problem with my z axis on mach3 | thesaent14 | Machines running Mach Software | 18 | 04-06-2007 05:28 PM |
