Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-16-2010, 05:33 PM
Sophiedoc is on a distinguished road
Proper use of "Z" inhibit
I am trying to loop3 passes 0.08 deeper each pass for a total depth of 0.24. I coded the final depth in the program run and set the "Z inhibit for 0.08 with the final line being M30.It rewinds but only makes one cut only instead of three.What command will make it cut progressively deeper?
Old 06-16-2010, 05:39 PM
ger21's Avatar
Z inhibit limits the depth to what you set it to. You either need to code all your passes, or, use the multipass wizard to do it for you.
Old 06-17-2010, 07:26 AM
In the mach user info it states the the program should be coded for final depth desired with the final code being M30.There is a picture of using L and the #(EG3) of loops required each cutting@ progressively deeper as specified in the "Z" inhibit setting but I can't find this window-where is it?
Old 06-17-2010, 10:55 AM
ger21's Avatar
The functionality your looking for was in older versions of Mach3, and has been removed, and replaced with the multipass wizard. As I said, Z inhibit limits the depth of cut.
Old 06-21-2010, 05:37 PM
Wizards are new to me.On the multipass wizard do you code for final depth and let the wizard calculate the number of passes or can the depth of cut and # of passes be edited in some fashion?
Old 06-21-2010, 05:50 PM
ger21's Avatar
Never used it, but Step Depth should be depth per pass, and I think Depth is the max depth.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
