Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-03-2010, 02:27 PM
evsourcef is on a distinguished road
Mach3 Home Switches do not stop motors
I had to reconfigure my computer after a virus made the computer crash the other day. Anyway, I got just about everything working right except for the homing switches. The z will move until the home switch is activated (when the LED lights up for M3 Home in diagnostics) then it stops and sets zero as that point. The x and y both move until their home switch is activated (LED lights up for M1 and M2home) but then they don't stop! The motor just keeps trying to turn and rams the table up against the column (the y axis). In the homing/limits tab I have home neg checked for x and y but not for z. Auto zero is checked for all 3. In ports and pins active low is checked for x home, y home, and z home under input signals. Any help?
Old 07-03-2010, 05:26 PM
krak's Avatar
krak is on a distinguished road
I just had this issue setting up homing for the first time. check that your inputs are active, on the correct port ( which was not the case for me) and the correct pin. See if that helps.
Newbie- Stop and home switches questions coloradonewbie DIY-CNC Router Table Machines 9 11-30-2009 10:16 PM
Can Mach3 to back farther away from home switches Bluedog Mach Mill 10 02-07-2009 08:40 AM
Limit, Home and E Stop Switches Mr.Chips General Electronics Discussion 15 01-17-2007 09:02 AM
Setting Up Mach3 with home switches jonblack Mach Mill 0 07-29-2006 10:12 PM
Home switches,E-stop advise jcwebb Xylotex 13 01-17-2006 08:10 AM
