Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Slow Zone problem
    Registered SScnc's Avatar
    Jun 2008
    Slow Zone problem
    I posted this in the CNC router section about a week ago and no one had an answer. I should have posted here to begin with...
    The vid explains it, slow zone works on the Z axis perfect but the X and Y slow zones do not work at all. Anyone know what's causing this ?
    Thanks!
    [nomedia="http://www.youtube.com/watch?v=fuY-NEJqsik"]YouTube- noslo6.mpg[/nomedia]
    I don't know why the youtube player screen won't work here on the Zone tonight ???
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    SScnc,
    Are you sure the Soft Max is set correctly,they may be set to long.
    If it is wrong Mach3 never reaches the "Slow Zone" position.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jun 2008
    Hi Jeff, Yes, I think they are correct. Both axis will move to the 43 and 33 positions and of course to zero. And they don't even slow down for zero positions. And the axis do slam to a full stop at those positions.
    Thanks,
    Steve
    Feb 2007
    U.S.A.
    Question
    Steve,
    Have you tried reducing the speed setting?
    Jun 2008
    I did reduce the speed from original settings and I think they are now at X= 20% and Y=50%. I'll try reducing it some more.
    And thanks for the graphic too,
    Steve
    Feb 2007
    U.S.A.
    Post
    Steve,
    50% is extremely high , especially since your machine has very high rapid acceleration.
    Jeff...
    Mar 2003
    Shelby Twp, MI....USA
    Also try increasing the length of the slow zone, just to see if it helps.
    Jun 2008
    Quote Originally Posted by ger21 View Post
    Hi Ger, I had done that but I went back and tried various settings from 50 to 500K and nothing changed. I did make a mistake in my post, the slow zones work on the Z and the Y, it's just the X that it's not working properly on. The X is the only belt driven axis I have at this point, I did change the velocity of the X in motor tuning from 801 to 25 and then the slow zone worked. But 25 is way too slow for this machine.
    So I'm guessing it must have something to do with my steps per inch, my Z is 25000 spi, the Y is set at 20000 spi and the X is 518.6721992 spi. But I really have no idea how to make it work.
    Jeff, the 50% is of course for homing and the X (y and z too) home perfectly so I don't see that as a problem regarding the slow zone unless I'm missing something. Oh and just to clarify, in the video when the X suddenly stops at the soft limits, it's not hitting any physical stops, that's just the soft limits suddenly stopping it.
    Any ideas ?
    Thanks,
    Steve
    Feb 2007
    U.S.A.
    Post
    Steve,
    The speed setting is a function of the slow zone, try reducing it to 5% on the X axis.
    Jeff...
    Jun 2008
    Quote Originally Posted by jalessi View Post
    Steve,
    Jeff...
    Oh okay, I did drop it to 10% this morning and no difference, I'll go out to the shop and try 5% and report back.
    Feb 2007
    U.S.A.
    Steve,
    After you change the speed setting make sure you click the "Save Settings" button otherwise the change you made may not take effect.
    Jeff...
    Jun 2008
    Hi Jeff, I changed to 5% on the X in homing and limits and settings are saved. Still no slow zone on X. I also turned the feed rate on my pendant down to 15 IPM for the X and no slow zone at all. Just for the heck of it I made the slow zone at 1000000, no change. I know other guys have belt driven axis and I assume their slow zones work so I must have something wrong.
    Thanks for the help so far,
    Steve
  • Page 1 of 2 12 LastLast
    1. HELP! Fanuc 3m slow CW Spindle problem
      By SSMrob in forum Fanuc
      Last Post: 10-04-2011, 08:11 AM
    2. Slow Zone problem
      By SScnc in forum DIY CNC Router Table Machines
      Last Post: 05-17-2010, 11:37 AM
    3. thanks to the zone
      By woodman08 in forum Hypertherm Plasma
      Last Post: 12-16-2009, 09:44 AM
    4. New to the Zone
      By brett008 in forum CNCzone Club House
      Last Post: 03-09-2009, 08:31 AM
    5. Problem in the Zone
      By mactec54 in forum Forum Questions or Problems
      Last Post: 04-13-2008, 12:16 AM
