Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-28-2010, 07:45 PM
electric2u is on a distinguished road
y axis slaving off
i have my y axis slave with A, the motor tune is the same, but when i run back and forth on the table and then check it, it is 5/8" off from the other slaved axis. can someone help.
Old 04-28-2010, 08:02 PM
ger21's Avatar
Are you sure both settings are the same? If they are, you're possibly (probably) losing steps on one axis.
Old 04-28-2010, 08:17 PM
so is there a way to find out if that is the problem?
G540 and slaving KTP Gecko Drives 13 03-08-2010 02:32 PM
slaving y axis motor for 4x8 cnc eloid DIY-CNC Router Table Machines 30 11-25-2009 10:27 AM
X/A axis slaving issues jhowelb Mach Mill 4 10-21-2009 11:41 PM
Slaving axis & other issues George Mach Mill 5 04-17-2009 03:19 AM
Slaving 2 axis together Mach3 retromulticam Mach Software (ArtSoft software) 1 04-29-2008 07:42 PM
