Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-22-2010, 08:07 AM
Praymond1209 is on a distinguished road
Machined size is double
Just finished my second milling machine project and am experiencing a weird issue. When I machine something using one of the canned cycles (wizards) in Mach 3 the machine cuts the exact size I program. When I machine something programmed in Surfcam, the machine cuts the part (circular pocket) twice as big. The code program indicates the correct dimension but the machine cuts it double.
Perplexed in SLC.
Old 04-22-2010, 10:41 AM
ger21's Avatar
Possibly an inch/metric issue? What are the native units set to in Mach3, and is there a G20 or G21 at the start of the code?
Old 04-22-2010, 11:17 PM
wwendorf is on a distinguished road
Perhaps Surfcam is set at diameter based programming while mach3 is set at radius programming?
I don't know Surfcam, but in my cam program I can set either radius or diameter based programming. I'm pretty sure that mach3 has somethin similar as well.
Wade
where to go to have MDF machined? jerchi DIY-CNC Router Table Machines 3 12-29-2009 05:41 PM
Via shape/size and wire size. Drools PCB milling 0 08-14-2009 09:47 AM
Drawing Size and Cut Size Differ - Plasma ADucci LinuxCNC (formerly EMC2) 5 10-05-2007 04:52 AM
Drawing Size and Cut Size Differ - Plasma ADucci Mach Plasma / Laser 0 10-04-2007 08:49 AM
X3 base size or minium bench size kenrc Benchtop Machines 2 02-04-2007 06:50 AM
