Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 03-19-2010, 12:29 AM
cboyce is on a distinguished road
Compensating for an unlevel table
I've noticed on fine detail work, the table on my fixed gantry mill is slightly uneven. For most parts this isn't a problem, but one thing I'd like to use it for is PCB etching, and so the vertical tolerances need to be pretty tight. Since I can fairly easily measure the amount I need to displace the Z position just by jogging and touching around, is there any way in Mach3 to compensate for this? I was going to make a script which automatically transforms the coordinates in the gcode, but I'm hoping for a more general solution.
Old 03-19-2010, 12:35 AM
MyCattMaxx's Avatar
MyCattMaxx is on a distinguished road
There are some threads on touch probing, but if it were me I'd make a pcb fixture and make it level by surfacing.
Just remount the fixture in the same spot every time you use it.
Or I would work at leveling the table.
010001110110111101110100001000000100110101101001011000110110010100111111
Maxx
Old 03-19-2010, 12:42 AM
The fixture is a great idea, I think that will be the easiest way for me to go. This is my first attempt at a home made CNC mill, and since everything is held together with wood and screws at the moment, fine-tuning the table level would probably be difficult to do with any accuracy. Thanks for the quick reply!
Old 03-19-2010, 12:50 AM
MyCattMaxx's Avatar
There is a thread here somewhere that someone made a nice fixture with a recessed area the pcb fits in to. He also had a spot along the edge that you could get at the side of the pcb for removal.
Maxx
Old 03-19-2010, 10:52 AM
ger21's Avatar
Surface your table flat with the machine.
Need Help!- Compensating for Tool Wear nfrees114 BobCad-Cam 10 02-25-2010 05:59 PM
Compensating for non-perpendicular axis lsteele DIY-CNC Router Table Machines 3 09-07-2008 03:29 PM
XY table design basics, linear ways to table size ratio? Konstantin Mechanical Calculations/Engineering Design 0 03-13-2007 12:21 PM
Compensating for ball screw lead error? Noah General Metal Working Machines 2 08-12-2004 08:51 PM
Compensating after stopping a move wjbzone TurboCNC 1 05-18-2003 10:45 AM
