Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 03-15-2010, 01:32 AM
jcambra is on a distinguished road
Zeros reset
I'm not sure that this is a software issue (running Mach 3) but I have my suspicions the problem is at the computer end and not the router end...the zeros of first just X and Y and as of Friday Z too, have been reset to another position without any changes made at the user end. This reset has occurred in the middle of cutting and while the machine was off or not running. And we're not talking a few inches here, it's usually 11in+, .5in on the Z axis. Read another thread about glitchy behavior solved by a windows update, I will try that. Does this sound familiar to anyone? Any other suggestions? Thanks!
Old 04-02-2010, 10:31 PM
electric2u is on a distinguished road
hay i have a problem do you know how to set the mechine coord's Zero i can not get it to set to zero every thing is good but the mechine zero can not get it to zero ( i'm trying to set up my table) if you can help thank you
kevin
Reset button = Hot key zaebis Mach Software (ArtSoft software) 1 08-04-2009 08:08 PM
Manual Setting of Work Zeros (0-M fanuc) venomgrrrl Fanuc 33 07-08-2009 12:43 AM
Why does my program reset MetalMolder Fadal 3 04-20-2008 03:32 PM
reset zero jrick Commercial CNC Wood Routers 7 01-13-2007 04:54 PM
VMC-966 (reset) )= novydcute General Metal Working Machines 0 10-18-2006 02:09 AM
