Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 11-01-2009, 02:50 PM
RobH is on a distinguished road
Thumbs up Spindle speed control with Sherline controller
Hello,
This is my first post, hope someone has an idea!.
I am running a Sherline cnc lathe with the Sherline control box and computer. I have installed Mach 3 as I found Linux Ubuntu a pain to set up. Everything is working OK but I would like to thread cut and need to control spindle speed from Mach3. Is this possible?. i.e. Does the Sherline controller have an input capabilityfor this.
Thanks.
Old 11-01-2009, 04:04 PM
leggazoid is on a distinguished road
You would need a spindle encoder, detects speed of spindle to sync z axis.
Here is an example, but I have no idea if it is overpriced or works good.
http://www.cadcamcadcam.com/latheencoderkit.aspx
Possibly this will do the same thing, not sure why they would use a stepper drive for anything else?
Some one please comment on the use of a stepper as a spindle drive...
http://www.sherline.com/6500pg.htm
Old 11-01-2009, 04:46 PM
Thanks Leggazoid,
Good start for me.
Old 12-17-2009, 03:15 AM
boutje is on a distinguished road
The encoderkit cadcamcadcam is not ok for mach.
This encoder has to many counts/rev.
Mach can only take about 4 to 6 counts/rev.
Old 12-17-2009, 08:49 PM
http://www.cnc4pc.com/Store/osc/prod...roducts_id=129
what about this index pulse card? would it work in mach3?
Problem- LNC510i controller, spindle speed. joblo WoodWorking 0 05-26-2009 09:53 PM
speed control with MIDI servo controller? dondeaida RC Robotics & Autonomous Robots 0 07-26-2007 09:05 PM
Sherline mill with spindle speed control rozon Benchtop Machines 1 07-15-2007 12:02 AM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 04:29 AM
Sherline Speed Control kaput mikkojay General Electronics Discussion 2 05-05-2006 12:59 AM
