Hi heightechkey
Yes you can use these drives with Mach control software you would be using Position control which uses Step & Dir comands to move your motors not the best for CNC but will work you also have electronic gearing to help smooth it out a bit
You can also get a step & dir to analog out put which would be +/- 10v Mach software puts out step & dir signal's
LinkBack URL
About LinkBacks
