Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 08-30-2009, 12:54 PM
adbradley is on a distinguished road
Combined home and limit switches driving me nuts!
I am setting up a denford orac lathe with a new controller and Mach3, but for the life of me, i cant figure out how to set up the home switches and limit switches to share one pin.
I have a limit switch on the x, and one on the z, they are NC, and they are wired in seriese. They work just fine as limit switches on pin 11, but i want to use them as home switches as well. When I turn homing on to pin 11, and try to home an axis, it his the switch, then gives me a limit switch error, and has to be reset.
I have read through the mach turn manual a few times, but just cant figure this out. Anyone have any idea what im doing wrong??
Thanx
Adam
Old 08-30-2009, 01:32 PM
TOTALLYRC is on a distinguished road
Thanx
Adam
Here is what the manual says.
When using home and limits together I am not sure if you can tie all the axis together. Try just the x axis and don't series with the z and see if it works. Then you could do the z on another pin.
Mike
"If you implemented configuration two from Section 4.5, you will probably have Home switches on
the X, Y, and Z axes. Enable the Home switches boxes for these axes, and define the Port/Pin to
which each is connected. If you are combining limits and the Home switch as one signal, then you
should enable Limit --, Limit ++, and Home for each axis and allocate the same pin to Home,
Limit --, and Limit ++."
Old 08-30-2009, 02:05 PM
I have tried that, with no luck. It is still interpreting it as a limit switch and stops the machine.
Old 08-30-2009, 02:06 PM
im sure im missing something simple
Old 08-30-2009, 02:19 PM
ger21's Avatar
Did you restart mach3 after setting up the home switch pins?
Old 08-30-2009, 02:24 PM
Yes i did, i just read of a similar problem on the artsoft's forums, they solved there issue by changing the debouncing to 2000, so im going to try that
Old 09-01-2009, 10:28 AM
Runner4404spd is on a distinguished road
THe home pins cannot be tied together. the limit switch pins yes. when homing mach does each axis indepently so if one finishes homing before the other it will stop there. on my lathe you have an x high and and x low limit, you also have a z high and a z low limit. you can use either of the swithes as both a limit and a home but you will still need to use a minimum of 3 input pins. 1 for the joint limit, 1 for x axis home/limit and 1 for z axis home/limit.
hope this is clear.
Old 09-01-2009, 12:00 PM
i will change my setup then, thanx runner4404
Old 09-01-2009, 02:08 PM
pminmo's Avatar
pminmo is on a distinguished road
Maybe this might help some in the future: http://pminmo.com/home-and-limit-switches
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 11-15-2009, 11:41 AM
mecheng10 is on a distinguished road
3-Axis Limit and Home Switches Sharing Single Pin
I have my 3-axis cnc mill set up to run the shared limit/home switches on all three axes from a single pin and it works fine on my machine so I know it can be done. When you set all the limits and home signals to the same pin Mach 3 is smart enough to know how to interpret the signal based on the context of the machine at a particular time. The only drawback I have found using this method is that the axes have to be homed sequentially (one at a time) which takes a little longer.
-Brian
  #11   Ban this user!
Old 02-24-2010, 09:33 PM
Fastest1 is on a distinguished road
Mech, the way I understood it you could do exactly what you are doing. I think and or I am hoping that I can even do that with only 1 limit switch on each axis. If I remember right you tell it which way to travel to find the limit switch and then it backs off a preset amount that you specified and as you say 1 axis at a time til all are homed. 1 axis at a time is better than losing position and having to start over at square one!.
-Brian
Combined limit/home switch config... jvanick LinuxCNC (formerly EMC2) 7 04-21-2009 07:56 AM
Home limit switches daisydog Commercial CNC Wood Routers 12 05-18-2006 11:55 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 02:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 07:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 06:32 PM
