Results 1 to 3 of 3
Thread: Nub - please help... what controller?
    Feb 2009
    ISR
    Hi Guys,
    i've been reading the posts on this forum and the knolage is awsome!
    i took the dive and got me a small lathe... i converted it to a CNC and the Jog is fine.. my problem is this:
    i'm using Solidcam 12 for Cam... i then generate a Gcode for the mach3 and i get error when trying to run the program.. i tried selecting:
    * Fanuc0T
    *Nakamora mt
    *Okumall
    thees are the only options i get, and non are working with Mach3...
    is there a post processor or something? what am i doing wrong?? please help,
    im ready to throw the D**n thing
    Cheers
    Liron
    Sep 2006
    Not familar with Solidcam so can't help you there. Most cam programs have postprocessors for Mach3. Does Solidcam have one? Also as you probably already know Mach3Turn has wizzards for most normal turning requirements. If you send me an drawing of the part I'll try to gen some code for you and see if it works.
    Jun 2005
    post your code so we can look through it. it might be really something simple. my cam program doesn't post an M03 which i like so i have to go in and add that myself. so then i check speeds etc to make sure they are correct. you maybe missing some small tid bit of info.
  1. Need Help!- To buy cnc controller
    By Olsson in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-16-2008, 10:11 AM
  2. add cnc controller
    By synv in forum SolidCam
    Last Post: 01-08-2008, 10:07 AM
  3. x2 cnc controller ?'s
    By maxboostbusa in forum Benchtop Machines
    Last Post: 10-23-2007, 05:40 PM
  4. DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller
    By maycom in forum DeskCNC Controller Board
    Last Post: 06-02-2007, 02:33 PM
  5. CNC controller
    By justCNCit in forum General Electronics Discussion
    Last Post: 03-23-2004, 02:32 PM
