Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 12-11-2008, 09:35 AM
skmetal7 is on a distinguished road
Mastercam Lathe ----> Mach3Turn
Ok so im just learning Mastercam lather and I have been using mach3Turn off and on for a while. This is the first time I have used mastercam for generating gcode and have this problem: I looks all fine in mastercam but when i try to run it in mach3 i get these weird arcs in these 3 places (see pics)
is it my post processor? im using the mplfan.pst my tool radius?
lost....
ID:	71330   Click image for larger version
Old 01-02-2009, 12:51 AM
simso is on a distinguished road
If your lucky, in mach 3 under settings general config it will have in about the middle of the page active plane of movement, untick x-z and say pick y-z then load your program and see what happens
Old 01-02-2009, 11:48 PM
hi!
what i did was edit the post processor, i read in another thread that you can change a setting and have it output a different arc type. so look at the pic and you can see what setting i changed. i havent experimented with different settings but #4 works so that is what ive been using.
Old 01-03-2009, 04:15 AM
Nice thinking outside the square, turn your mill into a lathe
Are you still using mastercam and then post processing out to mach 3 if so what settings in mastercam are you using.
Steve
Old 11-21-2009, 06:10 AM
skillakali is on a distinguished road
After a few hours of trying to look for the option I found it under Config -> Ports & Pins -> Turn Options -> Reversed Arcs's in Front Post.
Don't know why it's so hard to find it but oh well.
Need help on Mastercam lathe V9 Bob Z Mastercam 2 11-05-2007 08:23 PM
Mastercam V9 Lathe LIVVY111 General CAM Discussion 1 09-27-2007 09:06 AM
Mach3Turn - 1st 'Beta' release of the SilverBlue Screenset for lathes santiniuk Screen Layouts, Post Processors & Misc 4 03-08-2007 10:55 PM
how to communicate kia lathe with mastercam.? bala_51083 Mastercam 0 09-22-2006 05:12 PM
AutoCAD 2004 to Mach3Turn Edward Perera General CNC (Mill and Lathe) Control Software (NC) 0 05-31-2006 12:13 AM
