Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 11-28-2008, 01:25 PM
bullseye is on a distinguished road
Help with G77-G78
can someone give me an example of a G77-G78 canned cycle for use on Mach
I am used to using G70-71-72 at work........Thanks
Old 11-30-2008, 02:48 AM
Got the info I needed.....if anyone need it here ya go
G77
'(Xx.*********x XDia NEEDED)
'(Zx.*********x End Z NEEDED)
'(Fx.*********x Feedrate)
'(can be Set In the settings page: 'Hx.*********x Depth of cut)
'(Cx.*********x Clearance In the X)
'(Qx.*********x Clearance In the Z)
'(Kx.*********x ZStartpoint)
'(Rx.*********x XStartpoint)
'(Tx.*********x Taper In Deg)
'G78
