Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 10-31-2007, 10:10 AM
Jonne is on a distinguished road
Servo used spindle?
Can I use servo as spindle motor with step/dir pulses?
Mach3 manual don't tell... Or I can't just find right page...
Old 10-31-2007, 05:32 PM
acondit's Avatar
acondit is on a distinguished road
Jonne,
If you have an appropriate driver that accepts step and direction signals, such as a Gecko G320 or G340 and the servo has an appropriate encoder mounted on it. Then the servo can function as a "step/dir" spindle motor. The problem with Mach3 will be if it can generate the step and direction signals for the spindle at a sufficient rate to turn the desired rpm. The other problem you will face is writing the gcode to both keep your spindle turning and making the cuts you want.
If this is just to have a means of indexing the spindle, then it may be reasonable. If you are wanting a 3000rpm spindle then it is probably not a good approach.
So the real question is what are you trying to achieve and is this the best way to do it?
Alan
http://www.alansmachineworks.com
Old 11-01-2007, 07:02 AM
Thanks, I found that setup what I search.
It was Ports&Pins - Spindle Setup - Modbus/Step/Dir.
Indexin is not problem, I have pulse coder on spindle.
Second problem is how I control spindle servo. It's about 18 KW.
Maybe some IGBT-transistor bridge conected to servo controller?
Here's couple pics my project, I'm modernizing Nakamura TMC-4:
Old 07-11-2009, 02:36 AM
stallionturbos is on a distinguished road
i strukle as wel so i put 3 phase motor and speed controler on my lathe and a smal
servo motor on the same belt withe a rely and a gego drive to do indexing the servo
drive switch of wen i need some hi speed but i strukle withe mach3 settings to do so
Old 07-11-2009, 02:47 AM
please help i strukle to let my spidle go smoofly on g96 wen i face my stock
it go 5% on a time were on mach3 settings do i fix it. excuse my spelling
AC servo motor for the spindle david_geng Benchtop Machines 9 10-14-2011 05:37 PM
Servo for spindle motor?? turmite Servo Motors and Drives 14 11-30-2006 03:21 PM
AC Spindle Servo Unit HELP Darkos Fanuc 0 10-31-2006 12:05 PM
dc servo spindle anyone? jed102 General Metalwork Discussion 4 09-13-2006 10:06 PM
Servo motor as spindle?? GalaticDan DIY-CNC Router Table Machines 3 07-11-2005 01:17 AM
