Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 10-29-2007, 05:10 PM
scot1972 is on a distinguished road
Set Home on Mach3 Turn
Hi all, Does anyone know if it is possible to set a home position for Mach3 Turn. My other cnc lathe is a Pro-Light 3000, (American machine) which when i turn it on and start the software click the home button and both axis goto this position and every time. I think there is some limit switches in under the way covers which may have somthing to do with it. When using Mach3, if i reference tool 1 on the face of the work piece and set Z zero, the home position alters.... Any ideas?
Thanks...
Old 03-12-2008, 02:46 AM
rajiv.tctech is on a distinguished road
Chapter 6.2.8 "Using3Turn". Download the document from http://www.artsoftcontrols.com/docum...Using3Turn.pdf
Cheers!
homing with home swtiches and mach3 TMaster Mach Mill 7 08-06-2008 09:27 PM
New FeatureCam Mill (3axis) and Turn Posts for Mach3 chris59 Screen Layouts, Post Processors & Misc 1 04-05-2008 03:43 AM
Turn off the system beep in Mach3? fatal-exception Mach Mill 0 09-19-2007 03:20 PM
G-code manual for Mach3 turn? Green0 Mach Lathe 4 06-25-2007 08:57 PM
Setting Up Mach3 with home switches jonblack Mach Mill 0 07-29-2006 11:12 PM
