Can the threads be tapped with the use of a tapping head?
Scott
i need to turn about 500 bushings with 1/4-20 internal threads. i'm running mach 3 turn and it have a setup for threading. however, i don't know if i can drive a tap with this as i can't seem to find single point turning tools small enough to make the thread.
Scott
Consistency is a good thing....unless you're consistently an idiot.
can a tapping head be used horizontally? i don't mind using one, i would need to get one, i just want to see if what i have setup can do it already?
Runner4404spd,
We use Micro 100 tooling for 1/4-20 ID threading.
http://www.micro100.com/inch/it.html
Wayne Hill
Wayne,
thanks for the great link. i'm turning 304 stainless, any experience using the micro100s on this material?
thanks
Jerry
I use a tapping head on my lathe tailstock quite often. It's not often that I turn threads as my lathe is not all that great in this arena. I prefer to tap when possible.
Scott
Scott,
how do you work the tapping head in the tailstock? i'm familiar with their use on a mill, but have never used one on a lathe. also i have this setup for cnc operation on my 9x20. i can mount the tapping head in my gang plate, just curious how it works in a blind hole?
