Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 09-02-2005, 07:12 AM
aus-newb is on a distinguished road
Mach & Additional IOs
I want to run a auto tool changer (6 solenoids), auto gear change (3 solenoids), mist & flood coolant (2 solenoids) and a heap of imputs to go with that.
How can I do this with Mach. I believe some of this can be implemented with Modbus.
Has anyone done this? and what hardware might you use?
Craig
Old 09-02-2005, 07:36 AM
ger21's Avatar
you might want to get in touch with Brian at http://www.newfangledsolutions.com , although their web site seems to be down at the moment.
Old 09-02-2005, 07:44 AM
Thanks Gerry
I didn't realise they had info on this. I will check it out once they are back up.
Is there anyone out there that is running more IO's than 2 Printer ports can handle?
Craig
Old 09-02-2005, 07:53 AM
Chris D's Avatar
Chris D is on a distinguished road
Originally Posted by aus-newb
Thanks Gerry
Craig
Hi Gerry,
There are a couple of ways to do it
1) ModI/O & MOdbus feature
2) SerialIn feature and create your own protocol and hardware (this is route I am just starting to experiment on)
In both cases, they are new features and nearly anyone involved with it is still in the testing phases. I would think that this is your best bet, but you may have to wait a little while as the technology developes or is understood.
Sorry I can't be of more help.
Oh, and no, you cannot use more that 2 parallel ports with MACH
Chris
Old 09-03-2005, 08:33 AM
Barker806 is on a distinguished road
The server is down and I think it is going to be Tuesday before it gets fixed But the Modbus is very simple. It is not cheap but I think if you look at everything it will do it is cheaper in the end. There is 1 cable that hooks the PLC to the computer. and there are relays built into the PLC. The Relay's will run up to 5amp (I think) and you can have DC OR AC inputs. You can also have analog out and in. I have a Bp set up there that has a pot for setting the Feed and Jog rate. AND It is running that analog for the spindle drive. So now you know about what you can do here are the parts that I use.
Automation Direct DL06 PLC (20 in 18 out) and Programming Cable with an Adaptor.
It is going to be about $230.00 in Parts But it needs to be programmed... I have a program that I made and I install it for $50.00... That is a good deal because the programming software is 150.00 and you are going to have to learn how to program. I am working on finishing up the manual but there has been so much software to write that I have not had the time to finish the manual.
Well it is a 300.00 solution to a 500.00 dollar problem
Brian
Old 09-04-2005, 10:52 PM
Hi Brian
Could you point me to a link. I was not able to find anything on Modbus. (Do I need to log in ?)
The cost of the product seemes very reasonable, especially if I can get the extra functionality out of my machine.
Craig
Old 09-05-2005, 08:07 AM
Hi Brian
Craig
There is not much out there about Mach3 and the Modbus. There will be more in the very near future as the doc's come out. The simplest way to get into a PLC would be to send it to me so I can program it for you. I have the programs made for DL05's and DL06's. If you would like to look at them they are here www.automationdirect.com . Look under the PLC's and the DL06 is the one that I like the most .
I wish there was more I could give you but at this time there is no time....
Thank you
Brian
PS Getting modbbus working in Mach3 is VERY simple and I only have to send you a screen shot of the settings...
Old 09-05-2005, 01:41 PM
*Registered User*
ChrisJ is on a distinguished road
Brian,
I have a question for you. The programming that you have performed and offer for $50, it does not need to be specific to one's applications?
Chris
Old 09-05-2005, 01:54 PM
Originally Posted by ChrisJ
Brian,
Chris
The program that I have done just slaves the PLC to mach3. The inputs and outputs are set on the port and pins page by selecting PORT 0 and The PIN of the output or input. So If I wanted to have a limit switch on input 3 I would just put Port0 Pin3 and if I sit the switch on the PLC you would see it in Mach 3 on the Limit LED.
Hope that helps.
Brian
Old 09-05-2005, 02:20 PM
*Registered User*
Understood.
Thank you.
Chris
  #11   Ban this user!
Old 09-05-2005, 07:30 PM
Hi Brian
Can the donload be done remotely, (ie could you send me a file?) or does it need their software to communicate with the PLC. The reason I ask, is that the DL06 is available here in Australia of the shelf.
Craig
  #12   Ban this user!
Old 09-05-2005, 08:39 PM
You have to have there software to write to the PLC.. The Software is 150.00 and there isn't a way to right the PLC with out it.... if there is a way you can think around this I would be happy to do anythig that I can.
I need to finish the doc's so everyone and anyone can use the program that I have for the PLC.
Thank you
Brian
