Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
  #13   Ban this user!
Old 09-12-2005, 09:34 PM
aus-newb is on a distinguished road
Hi Brian
I am keen on one of the D0-06 PLC's. I have been going through my IO requirements, and will definately need the additional imputs and outputs to run my turrets. My hydraulic solenoids use 24V DC and I am shure the turrets use reed switches for position. Could you advise me on the approriate unit I require for this job. Also I will be powering the unit with 240V AC.
Craig
  #14   Ban this user!
Old 09-13-2005, 05:21 AM
Barker806 is on a distinguished road
If i were you I would be looking at the D0 - 06DR the specs are as follows:
Power Supply: 100 - 240V AC
Inputs: DC input 12-24VDC
Outputs: Relay Output 2Amp and there are 4 commons so you could have half running 110VAC and the other half could be 24VDC
The price should be about 215.00 USD.
Brian
  #15   Ban this user!
Old 09-13-2005, 07:17 AM
Hi Brian
How can I get in contact with you direct so I can make a purchase?
I had a look at your site and the tutorials there look great, very informative. I am shure I should be able to work out the ladder diagrams with a bit of help from people in my end of the world, and of course my Fanuc Ladder diagrams, eventhough they are written in Jinglish.
Craig
craig@nodigequipment.com.au
  #16   Ban this user!
Old 09-13-2005, 08:01 PM
Craig,
You can get me at brianb @ newfangledsolutions.com (You are going to have to take out the spaces). We will see what we can do to help you get what you need. I am in hopes to be ordering a few PLC's and a few MPG's this week.. I have been in training for some cam software and it is taking all of my time. I should be done at the end of the week
Thank you and have a great day!
Brian
  #17   Ban this user!
Old 11-28-2006, 01:43 PM
Drew's Avatar
Drew is on a distinguished road
Using two axis stepper output how many I/O are left? Thanx Drew
  #18   Ban this user!
Old 12-15-2006, 03:09 PM
Torchhead is on a distinguished road
Port 1 has 12 outputs. Each axis takes two. The other one not used for axis control can be used for other things (relays, LED's, etc) . Port 1 has 5 inputs. You can run a second parallel port and in MACH use pins 2-9 as either inputs or outputs. That gives you 12 more outputs and 5 inputs or conversly 13 inputs and 4 outputs based on the settings.
www.CandCNC.com
  #19   Ban this user!
Old 12-17-2006, 03:26 PM
Drew's Avatar
TH thanks for the reply.
So the total I/O is 34. Which for a input needy lathe would break down to
4 axis s/d outs, 18 ins and 12 outs.
  #20   Ban this user!
Old 12-18-2006, 10:07 AM
Yep. Look at the MINI-IO-Combo on our website. If you want to buy it ala carte you can do that too.
Tom Caudle
www.CandCNC.com
