Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 04-18-2011, 01:52 AM
jasminder is on a distinguished road
thermal expansion of lathe spindle bearings creating probem in threading
friends,
i realized that when i turn my machine on the rpms are very accurate. say 900 in the dro and 900 in the demanded tab. But after a couple of minutes it comes down to 870 to 880.
Why?
thermal expansion?
then it starts making problems in thread cutting. The pitch changes and the probelm begins. How to handle this problem? any experiences?
I think it is because of thermal expansion that jams the spindle a little bit.
regards,
jasminder singh
It is better to die for something than to live for nothing.
Old 04-21-2011, 02:24 PM
is something left to configure in mach?
Old 04-21-2011, 02:35 PM
ad64075 is on a distinguished road
What make/model machine?
Old 04-21-2011, 02:40 PM
it is a home made cnc
hi friend,
it is a homemade cnc here
YouTube - C:\Documents and Settings\Administrator\Desktop\100_6190_flv.flvbuild log is also on cncnzone.
i am using mach3 here
regards,
jasminder singh
Old 04-21-2011, 03:02 PM
I'm going to guess that your longitudinal feed is not in sync with your spindle. Meaning that as your spindle slows, the feed does not, causing the pitch to decrease (less threads per unit). This will happen if your program feeds in inches per minute instead of using feed per revolution. Does your machine have feedback/encoder on the spindle?
Old 04-22-2011, 10:26 AM
thread cutting mach3 pitch change
yes friend,
it has an encoder and i am using g95 mode in my entire program (feed per rev). But i am not using g95 in the threading cycle somewhere (how can i use it) it looks like
g76 x...z...p 0.035.. and some thing something. I will confirm it soon.
But is it possible to put feed per rev in threading cycle too? then how
Old 04-22-2011, 10:29 AM
With most machines, you would issue the feed per rev command in the same line as the cycle you wish to execute. Using your example: G95 G76 X... Z... and so on.
Thermal Expansion!!!!! dalworth HURCO 22 06-07-2010 02:07 PM
Need Help!- POM-C POM-H Thermal expansion? Backlash? slavkok Glass, Plastic and Stone 0 07-24-2009 02:49 AM
thermal expansion and contraction ? ACME General Metalwork Discussion 5 06-26-2007 01:44 AM
Thermal Expansion mikie DIY-CNC Router Table Machines 2 11-21-2005 08:45 AM
Thermal expansion and accuracy in huge machines? Splint Mechanical Calculations/Engineering Design 13 09-01-2005 09:49 PM
