Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 01-15-2011, 09:14 PM
nate is on a distinguished road
Unhappy lathe speed S and STrue wildly different...
I am running a stepper as a spindle motor and I cannot get the darn thing set up correctly.
Here is my setup-
Mach3
Smooth Stepper
200 step/rot pacsci 870 oz in motor.
14-44 tooth gear reduction. 1 : 3.181 Ratio
Gecko 203V
CNC4PC optical tach
I cant seem to get a steady tach reading under 175RPM. I am not sure what appropriate debounce seetings might be.
I have tried tons of settings under 'spindle pulleys' and 'motor tuning/spindle' and for the life of me I cant seem to get the motor to turn 1000rpm when I type in S1000.
This should be simple right? at 200steps/revo, with a 1:3.181 Ratio, I should have 636.2 steps/revo. then I set my pully ratio to 1:1, set my min/max speeds, set velocity and accell and...theoreticlly, I should have accurate control of my spindle. well, suffice it to say that it does not work the way I imagine it should...nothing jives.
Anyone have any insight? I have been trying to figure this out for over a year off and on, and I am reaching a new level of frustration...
Thanks,
Nate.
Nate.
Ann Arbor Meechigan
Old 01-15-2011, 10:47 PM
Sample Numbers.
Here is an example of what I am getting given a particular set of seetings.
Motor Tuning
Steps 6362
speed 100
Accel 10
Spindle pulleys
Min speed 0
max speed 3000
Ratio 1
With these settings, I get these results-
STrue 101
S 3000
I hope this example will help someone help me pinpoint the problem. I am at a loss and would really like a hand...
Best,
Nate.
Nate.
Ann Arbor Meechigan
Old 01-16-2011, 12:44 PM
Hood is on a distinguished road
Set spindle pulley Max to the same as the Velocity in Motor Tuning.
Hood
Old 01-16-2011, 12:53 PM
BTW with a stepper you are probably looking at around 1000rpm motor revs max and with the gearing that would mean probably about 300 spindle RPM.
Hood
Old 01-16-2011, 01:24 PM
Hood
sure, thats fine by me. this is just for threading and light indexing work like milling flats.
For normal turning I use a VFD and invertor duty motor.
Nate.
Ann Arbor Meechigan
Need Help!- Fanuc O-TD-controlled lathe machine at low speed and fixed speed problem. bursa017 Fanuc 0 06-11-2010 01:59 AM
New Lathe CNC Feeds and Speed Help. Cartierusm General Metalwork Discussion 1 05-11-2009 08:35 AM
Need Help!- C6 Lathe Spindle Speed LEN1042 Syil Products 0 04-17-2009 09:23 AM
Need Help!- Lathe spindle speed and lathe facilities GuntisK TurboCNC 4 10-26-2008 05:22 PM
Lathe Speed Control CrazyRonny General Metal Working Machines 15 06-01-2008 09:57 PM
